Removes an SNMP VPN identifier for traps from the specified VLPLS.
vpls_name | Specifies the VPLS for which you are removing the identification string. |
N/A.
None.
The following command removes the identifier for SNMP VPN traps on VPLS vpls1:
unconfigure vpls vpls1 snmp-vpn-identifier
This command was first available in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
